« Step-By-Step Guide To Push Your First Project On GitHub!!
April 26, 2019 • ☕️ 4 min read
GitGithubCodeRepositoriesProjects
Steps that can make your work half!!
Photo by [Samuel Zeller](https://unsplash.com/@samuelzeller?utm_source=medium&utm_medium=referral) on [Unsplash](https://unsplash.com?utm_source=medium&utm_medium=referral)
First select your project & open your terminal in your project’s root directory.
1. Check for Git Version
git --version
If it is not showing the version of git then go to the official website of git and download the git according to OS of your system.
2. If we are setting up the git for the first time, we can configure the git with name & email.
git config --global user.name "Your_Name"
git config --global user.email "Your-Email"
3. Initialize Git Repository
git init
Note:- On your Project’s root directory
It initializes the git repository in local project & will make .**_git_** folder that contain important folders and files.
4. Commiting files into the git repo.
There are three steps :-
Step 1 : We need to add a file to staging area .
git add <File_Name>  {{For Single File}}
git add .            {{For all the files in current Directory}}
Note :- In place of <File_Name> add your file and if you want select all the files in current directory then use {{ . }} or {{ * }}
Staging area :- Staging area is that area where we can buy some items and put them in bucket .
To check,if files are added or not,use this:
git status
Step 2 : Commit a file into the git repo is to write a commit message.
m = message
git commit -m "First Commit"
Note :- In the “Double Quotes”, you should write your message.
Step 3 : Push the file into a remote repository. {{Github}}
Now create your account on git-hub and create a repository .
To add files in your remote repo use this :
git remote add origin git@github.com:"Username_on_github"/"Repository_Name"
Note :- This above command is a single command & Now place your git-hub username (without any quotes) and put your repository name (without any quotes).
Like this
git remote add origin git@github.com:XYZ/project.git
And if you don’t understand this then go to your repository on git-hub and click on clone or download button and copy url with SSH method.
To check
git remote -v
5. Create SSH Key.
Why we use SSH?
By using the ssh protocol, we can connect and authenticate to remote servers and services. With ssh keys we can connect to GitHub without supplying our username and password at each visit with the help of passphrase.
In HTTPS method, you will need to fill our username and password at every visit, which will be very inconvenient.
Git associates a remote URL with a name and our default remote is usually called “Origin
1. Generating New ssh key and adding it to a ssh agent.
ssh-keygen -t rsa -b 4096 -C "email"
Note :- Place your email in “double quotes”.
This creates a new ssh key using the provided email as a label.
1.1. For default file Press {{ ENTER }}
/home/{{username_of_pc}}/.ssh/id_rsa: ENTER
1.2. Enter a passphrase.
1.3. Now our identification has been saved in
Private Key : /home/{{username_of_pc}}/.ssh/id_rsa
& Public Key : .ssh/id_rsa.pub
2. Adding our ssh key to the ssh agent
eval "$(ssh-agent -s)"
it gives like {{agent_id : 15800}}
3. Now we add SSH Private key to ssh-agent to our default path.
ssh-add ~/.ssh/id_rsa
4. Adding a new ssh key to your github account.
Copy the ssh key to our clipboard.
  1. Automatic Method (Using Xclip)
On Ubuntu
sudo apt-get install xclip
on Manjaro
Open Octopi -> Download Xclip
Xclip-set clip <~/.ssh/id_rsa.pub
2. Manual Method
Home/.ssh/id_rsa.pub
Open this file and copy your key.
Now goto github.com ➢➢ Under Profile Photo (Drop Down) ➢➢ Settings ➢➢ Use SideBar {{ SSH & GPG Keys }} ➢➢ Then go to this directory on your computer {{Home/.ssh/id_rsa.pub}}
Create new SSH key ➢➢ Title the filed with descriptive label ➢➢ Paste key into a “Key Field” ➢➢ Click on {{ Add SSH Key }}
5. Now for Testing SSH Connection.
ssh -T git@github.com
After running this , it will show this messege on terminal!!
Hi {{ USERNAME }}! You've successfully authenticated but github does not provide shell access.
6. Final PUSH
git pull --rebase origin master
git push origin master
Note : Change ‘master’ whatever branch to push.
Then you can successfully push your file to remote server and you can setup a SSH Connection.
To check the connection
git log
Some other useful git concepts.
There are concepts that can help you to understand the git more deeply.
1. Create a new branch.
git checkout -b Branch_name
If you want to switch back to master branch.
git checkout master
If you want to delete the branch.
git branch -d Branch_name
2. Update and Merge.
To update local repository to the newest commit
git pull
To merge another branch in active branch.
git merge <branch>
In both cases git tries to auto-merge changes. unfortunately this is not always possible and results are in conflicts.
we can merge those conflicts manually by editing the files shown by git.
git add <filename>
Before merging changes we can preview.
git diff <source-branch> <target-branch>
3. Tagging.
we can give tag (line 1.0.0)
git tag 1.0.0 {{1b2eld63ff}}
Note : {{ this is the first 10 characters of commit id. }}
4. Git Log.
By Git Log we can study repository history.
Advanced :
  1. See only the commits of a certain author.
git log --author <name>
  1. Very compressed log.
git log --pretty=oneline
More preferable format
git log --pretty=format:"%h - %an, %ar : %s"
3. It will only show the files that have changed.
git log --stat
5. Replace Local Changes.
git checkout --filename
(if we did something wrong) then this will replace file with the last content in HEAD.
If we want to drop all local changes and commits, fetch the latest history from server
git fetch origin
git reset --hard origin/master
6. Never forget to create your .gitignore file.
Gitignore file ➢➢ Is a file that specifying the files or folders that we want to ignore.
There are several ways to specifying those
  • Firstly, you can specifying by the specific filename. Here is an example, let’s say we want to ignore a file called **readme.txt**, then we just need to write **readme.txt** in the**.gitignore** file.
  • Secondly, we can also write the name of the extension. For example, we are going to ignore all **.txt** files, then write ***.txt**.
  • There is also a method to ignore a whole folder. Let’s say we want to ignore folder named **test**. Then we can just write **test/** in the file.
Like this
.gitignore file
.gitignore file
Useful Hints
1. Built in git Gui.
gitk
2. Use colorful-git output.
git config color.ui true
3. Use interactive adding.
git add -i
Some useful Article’s, Repositories & Tutorials
GitIgnore
Tutorials
Books
Photo by [Pankaj Patel](https://unsplash.com/@pankajpatel?utm_source=medium&utm_medium=referral) on [Unsplash](https://unsplash.com?utm_source=medium&utm_medium=referral)
Lastly, You are requested to share your views on this article. :)
Find something useful? Hold down the 👏 to support and help others find this article. Thanks for reading!!
Follow me on Instagram @hypnosisss___ :)
